Inventory
When playing this erotic game, You will experience an exciting journey full of surprises, adventures and erotic moments. You have to decide whether your hero will be kind or not, honest or not.
Post Reply
User avatar
PeepOwl
Inventory
Post by PeepOwl »
The capacity of inventory is determined by the character's clothing and can change. Everything that your character gets is saved in the inventory.
If you right-click on the item in the inventory, an additional menu of actions will open.
If the selected item is not unique or quest, then you can throw it away, use or donate it.
When using food or drinks, your character will somewhat quench hunger or thirst.
If you donate the subject to someone, then an improvement in relationships is possible.
Post Reply
