[RPGM] Old Heroes - Lewd Fairy Tales [0.7]
(Washed-up targets that couldn't handle my pump)
Post Reply
User avatar
elep3
Post by elep3 »
1: Expanded the miller's quest and added alternative paths for the 'bath' sequence (the miller will no longer just peep through a hole);
2: Fixed a dialogue looping issue for the miller (thanks to the support group for finding this bug);
3: Fixed a game-breaking bug in the witch's 'Herb Gathering' quest (thanks to the anonymous player who reported it);
4: Optimized graphical asset sizes, fixed text typos, and optimized several animations;
WARNING:
*v0.7 Update is fully launched! The build is 100% stable, polished, and ready for deployment on all platforms (PC/Mac links are live). Active development on the next content update (v0.8) has already started!
*All saves from previous versions are fully compatible! No need to start a new game!
🔥 MORE LEWD AHEAD! 🔥
Post Reply
