Hunting
The action of the erotic game «Adventures of stewardesses» takes place on a deserted island, or almost deserted, ... where our stewardesses find themselves after the urgent cabin ejection due to the failure of the aircraft’s on-board automatics.
Post Reply
User avatar
PeepOwl
Hunting
Post by PeepOwl »
Quest mode "Hunting"
When collecting the sleepy tree resin, you will have to fight off the rats. For this, you must have the required amount of coconuts.
Take care of this in advance, otherwise the rats will not let you complete the task!
Throwing coconuts is similar to casting a fishing rod. Press "Space" to throw, use "left" / "right" arrows to control the "projectile".
Post Reply
