Skills
When playing this erotic game, You will experience an exciting journey full of surprises, adventures and erotic moments. You have to decide whether your hero will be kind or not, honest or not.
Post Reply
User avatar
PeepOwl
Skills
Post by PeepOwl »
Foster your character's skills!
The level of the character's skills affects the success of his actions in the game world.
In total, the character has 6 skills that affects his development:
Athletics
Stealth
Break-in
Hacker
Fantasy
Persuasion
When completing quests, the character's skill levels are compared with a certain value, i.e. if the character’s skill is lower than the value required to complete this quest, the character will not be able to complete the task.
All skills are relevant not only for quest tasks, but also for everyday activities! For example: you will not be able to open a locked container without a certain level of hacking skills, as well as you will not be able to convince someone you are right without the required level of Persuasion skills.
Post Reply
