Quest mode "Fishing" For fishing, you need a bait, collect it in other locations. These can be butterflies, shellfish, and even berries. The items are updated once a day, just look carefully when visiting a location and you will see them... Yellow arrows indicate the transition to the quest scenes. Find a quest fishing location. To cast the fishing rod, press “Space”; use the “left” / “right” arrows to control. Fishing is simple – just watch the float and strike in time! |
