CRUISE TECHNICAL RULES
(Hire the badass harpooner and forget the panda, boss)
Locked
User avatar
Fierce Harry
Post by Fierce Harry »
📡 Connection to COMMAND POST: Your copy of the game must connect to our server via the Internet for just a couple of seconds, pal. Without this quick ping, the Harpooner won't receive your coordinates and won't know who needs to be toasted.
🔒 Hardware Lock: Your activation key is strictly locked to the hardware of the computer where you entered it. One key will not work on multiple different PCs, so don’t activate it on someone else's rig, old friend.
⚡ Auto Login: If you are playing on your own home PC and don't want to type in your code and email every time you launch the game, just tick the "Auto login" box in the menu.
Locked
