Designing a functional, sprawling environment inside a choice-driven text adventure requires an incredibly tight logic framework under the hood. While basic interactive fiction relies on simple text links to jump between static rooms, the developers of Tricky Gang implemented an expansive, evolving sandbox layout. The entire game environment is split into distinct map segments that players can explore fluidly regardless of the virtual time of day. Currently, the client hosts eight fully independent map areas, with continuous map expansion planned for future alpha build releases.
Navigating an environment of this scale naturally demands a multi-tiered vehicle mechanics script, which is coordinated entirely through a centralized world map dashboard. This travel layout becomes accessible whenever you reside in the designated starting node of any local area, marked explicitly as the far-left icon in your navigation dashboard. Once you enter this grid area, a red globe icon registers on your screen interface, serving as your primary launch trigger for fast travel.
However, the engine prevents you from engaging these travel routes if your protagonist is wearing indoor lounge clothing. Before you can interact with the open-world interface, you must open your equipment system and equip one of three specific active outfits: outdoor casual, outdoor athletic, or outdoor work clothes. Once your appearance complies with the systemic location rules, the engine opens up six distinct transport variables, tracking two variants of personal travel alongside four public infrastructure paths. You can select a personal car or a bicycle, or interface with public options like the subway system, transit buses, local taxis, and water ferries.
The core complexity lies in how the script applies rigid movement constraints based on your destination, attire, and physical status parameters. For example, maritime ferry travel is strictly locked to map areas sitting directly adjacent to the urban canal networks. Meanwhile, protected ecological sectors like the local park are blocked off for motorized travel entirely, leaving the bicycle as your only viable exploration tool.
The algorithmic rules governing individual vehicles prevent players from cheesing traversal cycles. If you choose the personal automobile route, Claire will refuse to operate the vehicle if her character status indicates intoxication, if she is wearing an athletic outfit, or if the destination target sits inside a green zone.
Choosing the bicycle path requires you to clear out your work or everyday outfits in favor of proper sportswear, and the engine automatically disables this vehicle option if you are heading out to run store shopping loops or if you are intoxicated. Public transit systems like the subway network and local buses follow identical logic paths, blocking your entry if you attempt to board while wearing sportswear or carrying a shopping list.
Taxis eliminate the shopping restriction but still enforce the anti-sportswear protocol, while the riverboat ferry follows the standard rules by blocking both casual athletic gear and retail runs completely.
Since this layout belongs to the broader Bathyscaphe anthology system, deep configuration parameters remain a work in progress, with certain optimized vehicle routes locked behind patron exclusive verification tags. Balancing these overlapping conditions turns a simple fast travel choice into a satisfying logistical puzzle that directly rewards systemic planning.
